Need to drain gas tank
I would suggest syphoning it through the gas fill hole with a silicone tube.
A friend of mine had her whole Honda Civic and their detached garage go up in flames when her father was replacing a fuel pump and the trouble light fell and broke igniting the spilled fuel. Luckily no one was hurt.
Couple of guys from my home town were driving an old pickup on a hot summer day. The old truck tended to get vapor lock and their fix was to reach outside the window and remove the gas cap(the caps use to be right behind the door on the pillar). A stray spark ignited the fumes and killed them both.
I know the last one is a little morbid ... BUT YOU CAN'T BE TOO CAREFUL!
The obvious thing is to drive it until it is as near empty as possible but obviously, that is about as much use as the 'use the pump itself' method!
Any other suggestions?
