coolant tank not holding pressure...
Old Apr 3, 2009 | 08:33 AM
audiphobic1's Avatar
Default coolant tank not holding pressure...
'01 A6 2.7T
Been suffering coolant loss for some time. Recently it has been getting severe.
Still trying to rule out the need to replace the secondary water pump. How can I be sure that I need to replace it? What else should I consider? Would the need to replace the secondary pump cause my vehicle to run hot..which it never does..go figure?
I usually got a good amount of pressure when I loosened the coolant cap when it was sufficient warmed up, now not at all. Could this contribute to my recently extreme coolant loss? What could cause the coolant tank to not hold pressure anymore? Other than the danger of not having any coolant, are they any other risks?
Thanks to everybody that has helped me on this board before and in the future!!!
Old Apr 3, 2009 | 08:59 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Could be the cap, could be a leak. Do you see any traces of coolant anywhere in the engine bay, or smell coolant?
Old Apr 3, 2009 | 09:17 AM
BernieBenz's Avatar
The cap establishes the max coolant pressure, contains an over pressure relief valve. Any fluid exhausted thru this valve exits thru a hole in the bottom of the reservoir. Feel the underside below the cap, two square projections,fluid will drip from hole between them.
This lost fluid will run down thru the maze right, PS, of the engine. Coolant loss from a failing after run pump will run out the rear of the engine’s V and down onto the bell housing. Should be easy to determine from which area the fluid is coming.
Old Apr 3, 2009 | 10:31 AM
Thank you for the response. Would a bad coolant cap ever cause the coolant to be purged completely from the tank? Prior to this past week, the coolant would sometimes stay at the same level and sometimes it purges completely. Being that the cap doesn't hold its pressure anymore, it seems as though it is happening much more frequently. Is there a connection, or am I just crazy.
Old Apr 3, 2009 | 12:12 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Don't get too excited, the pump is much more likely to fail than the cap. A prolonged slow leaks leaves pink residue. If no residue near the cap, look elsewhere.
My money is on the pump. Better find that leak before something ruptures.
Old Apr 3, 2009 | 12:21 PM
TNAvant's Avatar
New Member
I had a similar issue last year and found that the expansion tank had a hairline crack in it. Replaced the tank for next to nothing from AutohausAZ, added some more coolant and life was good.
Old Apr 3, 2009 | 02:10 PM
BernieBenz's Avatar
Coolant residue would not be evident around a failed cap, inasmuch as it would leak out the bottom of the reservoir. But agree, pump seal, main or after run, more likely than cap.
Old Apr 3, 2009 | 03:59 PM
Would a failing after run pump keep my coolant tank from holding pressure?
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 3, 2009 | 04:16 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Ideally, there should be very little pressure in the cooling system, but pressure does tend to accumulate. It's not the tank that "holds pressure", it's the system. If your system does not "hold pressure", there is a leak somewhere. A leak tester can pressurize the system and help locate the leak, but usually the pink coolant leaves a pink, chalky residue, even under the coolant bottle and on the frame rail if the cap is leaking.
The weak points of the system are the secondary coolant pump, which rarely runs, but it used to circulate coolant to the turbos in extreme heat shut off conditions, and the coolant tank. Look for the pink.
Old Apr 3, 2009 | 04:19 PM
squidix9's Avatar
No Bozos!
A bad pump or pump seal wouldn't cause the tank not to hold pressure, it would cause the system not to hold pressure.
On the topic of caps though. When I first bought my pressure tester I of course had to try it on a bunch of cars at the shop. I found MOST of the caps wouldn't hold full pressure. Nearly all of them held around 6-7lbs, but few held over 10lbs.
