Special Tools
Regarding the leaks at the head, there are valve cover gaskets, cam adjuster seals (2), cam seals (4) and cam plugs(2), all of which can leak near the valve cover gasket.
If you opt out of timing belt (again, bad idea, IMHO) you should be able to get both cam adjuster seals, both cam plugs, and the cam seal on the back of bank two (left side).
