2:00 flashing light - make it stop
I would replace all the motor and transmission mounts to make sure you dont rip the exhaust apart and keep the motor located. My flex section tore apart (probably from age and not from the additional power) but the new 42dd DP hits everything as the motor is flexing in every way. I replaced the dogbone bushings, and putting in the zf motor mount tonight (and the trans one later, ecs is out of stock) I hope that will cure the exhaust hitting.
But I like the flash program.
