is there a write-up for DIY timing belt on a 4.2?
Old Apr 7, 2009 | 07:17 PM
jdorp_'s Avatar
Default is there a write-up for DIY timing belt on a 4.2?
i've searched and read that there was one out there, but could not hunt it down.
Old Apr 8, 2009 | 06:29 AM
TrdLtly's Avatar
You won't find a timing belt on a 4.2. Search for "timing chain" and see if you come up with something.
Old Apr 8, 2009 | 06:32 AM
bac2h's Avatar
Ace Ventura
Default ummmm...not exactly...Kris Hansen did it on my 00 4.2 and it was definitely a belt
You should be able to search under the archives as I did a writeup on it from the summer of 2007 I believe. If BD is around he'll find the link quick for you. Not sure where you got the timing chain idea from.
Old Apr 8, 2009 | 07:18 AM
TrdLtly's Avatar
Whoops, I was wrong again. Don't tell my wife.
I did find this link on another site that should apply:
http://www.audipages.com/Tech_Articl...breplace0.html
Old Apr 8, 2009 | 07:32 AM
jdorp_'s Avatar
yah, i found that one. it is for an older 4.2 in the a8, i know it will be similar, i just thought that there was one on here.
Old Apr 8, 2009 | 07:38 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
It's basically the same as the 30V V6.. very slight differences, but the job requires the same tools, and same time.
Old Apr 8, 2009 | 08:39 AM
Boston Driver's Avatar
AudiWorld Expert
This?
https://www.audiworld.com/forums/sho...ht=timing+belt
Oh, and the timing "chain" is probably because the 4.2 in the allroad had the chain vs. the belt, yes?
Old Apr 8, 2009 | 09:37 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Please, please try to post in the correct section of the thread.
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 8, 2009 | 09:52 AM
alightman's Avatar
Everyone is correct. The first 4.2s had a belt only, then they went to a chain for exhaust and belt for intake, the later V8s had a chain only.
Old Apr 8, 2009 | 09:57 AM
Head Cat Herder
25 Year Member
Right, the belt drives the exhaust cams, and each exhaust cam drives it's intake cam, just like he 1.8t and the 30V 2.8 V6.
Stone77
Jul 15, 2010 06:44 AM
TJR
Jan 11, 2007 08:57 AM
omikelo
Jan 24, 2006 04:37 AM
cgriff
Jul 1, 2004 04:18 AM
