255-40-17 on S4 wheels, on A6 2.8Q narrow body. Works?
Old Apr 9, 2009 | 07:39 AM
gubro30's Avatar
Member
Default 255-40-17 on S4 wheels, on A6 2.8Q narrow body. Works?
Will there be enough clearance? Wheel is 17x7.5 S4/S6 replica, tires 255/40 Yoko's. Offset is 42 I believe.
Thanks!
Old Apr 9, 2009 | 09:01 AM
Shaun's Avatar
25 Year Member
Default That tire is too wide for the wheel...
8.5-9.0" wheels are recommended for 255 series tires, iirc (Although wide body A6s came with 255/40/17 on 8" wide wheels). I think your 7.5" wheels will be too narrow. You're better off sticking with the OEM spec 235/45/17 size. It's plenty of tire for our cars, imo.
Old Oct 15, 2009 | 07:31 AM
tehA8PIMP's Avatar
I plan to use D2 A8 wheels, 17" and ET48 on my 2004 A6 4.2. Anoyone done this before?
Old Oct 15, 2009 | 08:39 AM
monkeytronic's Avatar
On the '02 A6 4.2, I'm currently running 255/40-18s on 18x18.5" ET30 RS6 wheels. Figure that higher offset wheels (ET42 and ET48) will push a wider wheel/tire combo inboard and it could end up contacting and rubbing on the steering knuckle.
That said, while V8 A6s have wider fender flares than V6 A6's they also have a wider track as well--like 2" wider--so the overall space to play with between the fender lip and the steering knuckle compared to a V6 A6 could be more or less the same AFAIK.
Old Oct 15, 2009 | 01:50 PM
4Driver4's Avatar
Tech Guru
Tech Guru
I've got a set lying around (for sale!) if you want to test fit one.
Old Oct 15, 2009 | 02:34 PM
tehA8PIMP's Avatar
thx tom, i have a loose set as well, just want to make sure before I mount the 255s
lava man
Wheels & Tires Discussion
Jan 16, 2007 12:47 PM
cnair
13
Mar 19, 2003 10:33 AM
Audifficinado
Aug 29, 2002 09:04 PM
Stoney
Nov 25, 1999 04:06 PM
Muhammad
Aug 26, 1999 08:20 PM
