Alarm did not go off during entire wheel swap task...
I had to whale (as in "to hit, thrash, or beat soundly") on the winter rims with my rubber boots to break them off the hubs.
Never once did the car alarm go off. I was quite shocked to learn it was locked the entire time (I had to get my car keys to fetch the tire pressure guage from the glove box).
I want to make my alarm "just a bit" more sensitive... and will break out the VAG-COM and investigate the issue sometime soon.
Any similar experiences out there? My car is a 2001 A6 2.7T.
/dan
Anti-theft alarms triggered by Central Locking control module:
- unauthorized opening of trunk lid/tailgate
- unauthorized opening of hood
- signal from ultrasonic sensor control module
- unauthorized opening of driver's door
- unauthorized opening of front passenger door
- unauthorized opening of rear left door
- unauthorized opening of rear right door
- unauthorized removal of car radio
- unauthorized starting (shorting between terminals 30 and 15)
The ultrasonic sensors in the upper right/left B-pillar trim monitor the door windows and relay the monitoring signal to the ultrasonic sensor control module.
- Alarm from front anti-theft sensor (1)
- Alarm from rear anti-theft sensor (1)
- Attempted break-in via front left door window
- Attempted break-in via front right door window
- Attempted break-in via rear left door window
- Attempted break-in via rear right door window
- Alarm via glass break sensor (2)
NOTE 2: the glass breakage sensors (left G183/right G184) for the rear side windows and the conductor loop in the rear window provide external vehicle security, however only for the Avant.
/dan
