Increasing displacement from 1.8 to 2.0...
I have not seen stroker cranks for these. But if you find one for a 225hp I am sure you will have to sell a kid in india or china to afford it.
For the most part. Your main option is to bore the block and change rods and pistons. Or get pistons that are taller or shorter depending what you want and reuse the rods.
You can either use an AEG crank, or a 2.0TFSI crank, and then get pistons and rods to match.
This runs around $1500-2000, but then you have to worry about fueling and software. All together not a cheap mod.
TTransport on Q-W has a 2.2L BT build... you could probably ask him about it as well.
http://audifreaks.com/showthread.php?t=26
