Battery Charging Issue?
Old Apr 20, 2009 | 06:56 PM
wvcdhigh's Avatar
New Member
Default Battery Charging Issue?
I just did my timing belt in my 2004 A6 2.7T (pain in the butt - I don't recommend it). When finished (2 days later) battery was too weak to turn over. I put my cheap old charger on it, it took a 10 Amp charge for about 30 minutes, then the horn on the car kind of "burped" and the charger quit charging. I repeated that process again tonight, with the same results. As I was removing the charger, I heard something in the engine compartment click, like it reset. So I hooked the charger back up, and it started charging again. Any ideas what is going on?
Old Apr 21, 2009 | 02:55 AM
4Driver4's Avatar
Tech Guru
Tech Guru
The alarm is going off. Disconnect the battery before charging it...although it sounds like you need a new battery.
Old Apr 21, 2009 | 07:49 AM
wvcdhigh's Avatar
New Member
I don't think it's the alarm going off. There is only one "chirp", right when the charger quits, and it is from the front horn. I thought the alarm horn was trunk mounted. I don't doubt that I could have a bad battery, though. Vehicle purchased 1 yr ago as certified used, so I have no idea how old the battery is.
91quattro
Jun 17, 2017 11:36 AM
Sam2000
Aug 28, 2009 03:45 PM
|skolnick
May 23, 2007 05:27 PM
thomasj1
Audi 100 / A6 (C4 Platform)
Nov 13, 2005 11:22 PM
benk
Oct 18, 2002 04:42 AM
