Negative camber for 01 TTQ
Old Apr 20, 2009 | 06:59 PM
trussard's Avatar
Default Negative camber for 01 TTQ
Hi, my car is lowered with H&R coilovers. For some reason the rear wheels are in very noticable negative camber and resulting really bad uneven wear on my tires.
I was asking my local mechanic if I can fix that for my upcoming new set of tires, but he said the rear cambers are adjustable for TT and 4 wheels alignment won't fix the issus as well.
May I pls get some advise from you?? Thanks v much
Trussard
Old Apr 20, 2009 | 07:24 PM
XCLR8TT's Avatar
Senior Member
Unfortunately there is very little you can do with the stock suspension alignment wise. You'll need a set of K-Mac adjustable rear bushings for the control arms. Or at least a set of adjustable arms on the bottom.
Old Apr 21, 2009 | 05:59 AM
robertTT225's Avatar
Totally correct.. : )
Old Apr 21, 2009 | 06:38 AM
Krissrock's Avatar
I've got a half KMac (brand new) if you like.
Old Apr 22, 2009 | 07:30 AM
blktt92's Avatar
do you need a full KMAC set or a half set to fix negative camber in the rear?
Old Apr 24, 2009 | 03:52 AM
minibabe's Avatar
New Member
wondering the samething if you could get away with only using the 1/2 kit instead of the full kit.
thanks
Old Apr 27, 2009 | 03:38 PM
Forshaw's Avatar
Trussard
I also have the same issue which is what happens when the TT is lowered. However, since I hardly drive my car (I live and work in NYC) I opted not to install the kit. I have a '01 TT (225 HP upped to 265 HP chipped) with only 10K miles so my tire is minimum and not noticeable. Since I installed my coilovers 3 months ago I only clocked 100 miles. If you do drive a lot you definitely need the kit.
Good luck.
awc.
Old Apr 27, 2009 | 05:17 PM
Audiboy's Avatar
If your TT happens to be one with unequal rear control arms, then you may be in luck. Tell your mechanic to swap the slightly longer bottom with the top one, and use the top one at the bottom.
Then he can fine tune Toe on the front trailing arm attachment point. You should gain close to 1.5 degrees of positive camber back and you may end up with 1 to 1.5 degree of negative camber with a 2" drop from stock. I measured this all myself although this was part of getting my CPP arm constructed way back when.
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 28, 2009 | 08:23 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Good luck.
awc.
What happens: https://www.audiworld.com/forums/sho...php?p=16721626
Old Apr 28, 2009 | 10:22 PM
trussard's Avatar
Thanks Audiboy, I'll ask my mechanic to see if he can swap that.
Also, anyone know how much is the half KMac kit or full kit..whatever needed?
40v-V8
Nov 11, 2008 12:59 PM
invncble
Aug 18, 2008 04:40 PM
nvr_follow
Jun 4, 2008 01:43 AM
T Audi T
Apr 23, 2007 08:02 AM
nverfollow
11
Jul 22, 2004 08:43 AM
