Old Aug 15, 2016, 10:11 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A6 (C5) Interior Guides
Print Wikipost
2001 Audi A6 "POWER WINDOW ISSUE" HELP!
Old Apr 21, 2009 | 08:04 PM
Top_Dog's Avatar
New Member
Default 2001 Audi A6 "POWER WINDOW ISSUE" HELP!
Hi, I have a 2001 Audi A6 and the power windows will not go up or down at all!, it should be something simple like a relay or the master window control, but I just started getting into Audi's so I figured asking you guys on here would be a better IDEA. I would like to think that someone else had this problem or knows someone that had this problem. can you tell me what to check for and where the part would be in the vehicle? thanks ahead of time, J
Old Apr 21, 2009 | 09:56 PM
Max_Power's Avatar
I'm not an Audi expert but I will the electric windows fuse first. I believe the fuses should be at the side of the dash...
Old Apr 21, 2009 | 11:38 PM
Audi42LV8's Avatar
Mine has a problem going up.. I think the mechanic said its a window regulator. It jams into the door and Audi's technology if it detects that it hit something say your hand gets caught it will go down automatically.
Old Apr 22, 2009 | 12:46 AM
Top_Dog's Avatar
New Member
YEAH IT IS NOT THE FUSES OR REGULATORS, "NONE" OF THE WINDOWS WILL GO UP OR DOWN!!!! HAS ANYONE HAD THIS "EXACT" PROBLEM???? THANKS, J.
Old Apr 22, 2009 | 12:48 AM
Top_Dog's Avatar
New Member
WHERE IS THE MASTER WINDOW CONTROL LOCATED???
******ALSO, WILL A 97-01 A4 MASTER CONTROL WORK?
Old Apr 22, 2009 | 02:53 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Default Two things for you to try:
First, please ease up on the caps. Yelling is rude.
Second, please try to post at the correct location within the thread. Try threaded view to see what a train wreck this thread is.
Thanks.
For your problem, is everything else working? Headlights, climate control etc? If so, check the fuse. If not, check the ignition switch or x-relay.
Old Apr 22, 2009 | 02:54 AM
4Driver4's Avatar
Tech Guru
Tech Guru
It's the window guides. Common issue. There is a TSB on this.
Old Apr 22, 2009 | 05:06 AM
Boston Driver's Avatar
AudiWorld Expert
Caps lock...
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 25, 2009 | 04:08 PM
Top_Dog's Avatar
New Member
really window guides huh??????????
that is a coincidence, all "4" window's don't go up or down because of window guides!!!
you must spend alot of money fixing your car with that type of diagnosis!
it cannot be the window guides, window channels, fuses, or regulators!!
those have all been checked.
"IT HAS TO BE A MASTER CONTROL OR SOME TYPE OF MAIN RELAY"
**************Doe's "ANYONE" know where the master window control unit is located?*************
thank you
Old Apr 25, 2009 | 06:12 PM
dalgin's Avatar
Default dude! chill out! no need yelling. if you dont like the answer,
you can simply ignore it. people are trying to help you here and they have good intentions. you cant just come in here, register and start yelling at people.
