Rough Idle Start
Old Apr 26, 2009 | 10:00 AM
SporTTy's Avatar
Junior Member
Default Rough Idle Start
So I changed my plugs ( NGK - PFR6Q ) as well as changed all 4 coil packs, and coolant temp sensor a few days ago and everyday I have started the car hot or cold engine, I get a rough idle at start for like 5 seconds as if it wants to shut down til I throttle up a bit sometimes.
Whats up with that???
120K miles on the engine, full timing belt service done at like 98K miles
Old Apr 26, 2009 | 03:21 PM
Buttaz's Avatar
New Member
Try plug it into vagcom, and see if any of the cylinders are being misfired.
-buttaz
Old Apr 26, 2009 | 03:37 PM
SporTTy's Avatar
Junior Member
I just ran two different OBD-II scanners ( V-checker and Actron )....the V-checker is new to me that I got from ECS Tuning a week ago, however the Actron I have been using for years and know that it would display any misfire on any cylinder....upon checking, I found No misfires reported on either OBD-II scanners. No codes either for anything.
Old Apr 27, 2009 | 07:41 AM
AudiMick's Avatar
My 2001 does that also. Haven't figured out why.When it's cold it always starts but sometimes stumbles for the first 5-10 seconds or so. If I try to rev it slightly I have to press the gas pedal very gently otherwise it will stall
I checked the plugs and was planning on replacing the 5 year old coil packs and temp sensor next weekend.
I am occasionally (about 1 / month) getting a CEL for a rich condition and at different times a ESP problem.
Apparently this may be a MAF problem.It's kind of an involved explanation on how a MAF affects the ESP.
Not sure if this has anything to do with the weird starts though.
Old Apr 27, 2009 | 09:16 AM
Buttaz's Avatar
New Member
Bring it to a garage that can smoke ur hoses... There might be a leak in the hose and causing idling to be rough. It happened to me, one of the lil hose split in half, I forgot the name of the hose. But it wasn't the coil/spark plug or the wiring like I thought it would, also thought it was a failed MAF... but that should give you code as well... So have someone smoke the car out for you that should give u an answer... =)
-buttaz
s4ut
Dec 23, 2018 10:27 AM
b6maroon
Jan 20, 2016 03:59 AM
changoo
Dec 15, 2010 09:51 PM
Holographic77
18
Dec 19, 2006 02:03 PM
S4gasm (LoTR)
Jul 25, 2004 11:57 AM
