No high beams, turn signals, fog lights
Old Apr 26, 2009 | 06:05 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Default No high beams, turn signals, fog lights
This is a new one on me. The car has no turn signals, no high beams at any time, and the fog lights (front and rear) are non-functional. 4-way hazard flashers work fine. No power the fuses for the high beams and the fogs.
Old Apr 27, 2009 | 05:19 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
no highs at flash to pass? Load reduction relay?
Old Apr 27, 2009 | 05:23 AM
Boston Driver's Avatar
AudiWorld Expert
If it was just the high beams and fogs, I'd say maybe the headlight switch, but the turn signals are unrelated to that switch. If it was just the high beams and the turn signal, I'd guess the signal stalk, but the fogs are unrealated to the stalk. I'd also guess the fog relay, but I do not think that is related to the high beams or the turn signals.
Odd...
Old Apr 27, 2009 | 05:32 AM
4Driver4's Avatar
Tech Guru
Tech Guru
No flash to pass. AC, wipers, etc all are working as normal.
I'm not sure how much that relay does; it might be a double pole or something. I'll look into it.
Old Apr 27, 2009 | 05:41 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Cruise isn't working either, but that may predate this issue.
Old Apr 27, 2009 | 06:47 AM
4Driver4's Avatar
Tech Guru
Tech Guru
AArrggg! I hate Bentley Publishers. eBahn Reader errors out when I try to view wiring diagram.
Old Apr 27, 2009 | 06:55 AM
Head Cat Herder
25 Year Member
try this one out...
http://audi.kris-hansen.com/bentley/audi.c5.wd.25.pdf
Old Apr 27, 2009 | 07:44 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Oye. That's gonna keep me busy for a while - lol Huge thanks!
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 27, 2009 | 07:46 AM
Head Cat Herder
25 Year Member
No sweat. Start around page 16..
Old Apr 27, 2009 | 08:16 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Been poking through it (that's why it took so long to respond). I think I might know the answer.
To reinstall the cluster, I telescoped the steering wheel all the way out toward me. If I unplugged the wires to the turn signal stalk, that might be the issue. Will report back tonight.
