8 DTC codes... Help!
Old Apr 30, 2009 | 03:40 PM
vellnueve's Avatar
Default 8 DTC codes... Help!
17755 - P1347 - Bank2,Crankshaft-/Camshaft os.Sens.Sign. Out of Sequence
16684 - P0300 - Random/Multiple Cylinder Misfire Detected
16690 - P0306 - Cyl.6 Misfire Detected
16689 - P0305 - Cyl.5 Misfire Detected
16688 - P0304 - Cyl.4 Misfire Detected
18406
18404
17799 - P1391 - Camshaft Pos.Sensor,Bank2 Short to Ground
Got a CEL this morning and ran VAG-COM just now. Got these results (not sure what the two 18xxxs are)
2003 A6Q 3.0
Symptoms - when going from drive to park the idle was very rough, jumping up and down a few rpms and then doing one big jump before smoothening out.
Also, I had a flashing CEL that appeared twice, for a few seconds at a time, in the past few weeks. Any idea what the hell is going on?
Old May 1, 2009 | 03:50 AM
audi01a6's Avatar
got some coil packs going out,looks like drivers side,replaced all if u can
Old May 1, 2009 | 06:00 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Pretty clear to me that a cam position sensor is failing, which is causing multiple misfires on one bank.
Old May 1, 2009 | 09:44 AM
vellnueve's Avatar
Is that something that you can DIY? I'm not particularly great with cars.
Old May 1, 2009 | 09:49 AM
vellnueve's Avatar
And where is the sensor located in a 3.0?
Which side is Bank 2?
Old May 1, 2009 | 12:07 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Bank two is the left side. Other than that, the 30v is a mystery to me.
Old May 1, 2009 | 01:16 PM
vellnueve's Avatar
Hmm... Guess I'll wait for the part to arrive and then hunt for something that looks the same.
GuyWithanAudi
Sep 23, 2011 07:26 AM
Onebad S4
Mar 12, 2008 03:32 PM
WesS4
Jan 2, 2008 04:45 PM
b5s402
18
Jul 24, 2007 06:14 PM
fourwheelslide
9
Mar 12, 2006 02:25 PM
