Another coolant leak ?: what are possible sources based on the puddle location...?
Old May 1, 2009 | 05:58 AM
gak27's Avatar
Default Another coolant leak ?: what are possible sources based on the puddle location...?
'00 2.8 Avant. I noticed the level going down slowly in the reservoir but didn't see any evidence on the ground/engine until recently. The puddle (more of a "wet spot" actually) is on the passenger side towards the rear of the engine. Any ideas on what the possible leak areas are? The car is going in to the shop on Monday but I was hoping to have some ideas in advance.
Thanks all!
Greg
Old May 1, 2009 | 08:50 AM
audi01a6's Avatar
the temp sensor is on that side,also on driver side rear of eng there is a little nipple that gets loose and it leaks from there,hope that helps
Old May 1, 2009 | 09:18 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Funny, I've got almost exactly the same leak all of a sudden..
Old May 1, 2009 | 09:49 AM
Boston Driver's Avatar
AudiWorld Expert
Don't forget that the belly pan (the lower engine shield) may be masking the true location of the leak
Old May 1, 2009 | 09:56 AM
Head Cat Herder
25 Year Member
Belly pan? What's that?
LOL!
Old May 1, 2009 | 10:05 AM
AudiWorld Expert
Oh...you removed yours, right???
Old May 1, 2009 | 10:06 AM
Head Cat Herder
25 Year Member
Well, *I* didn't remove it.. the 3 feet of snow I was trying to drive through did.. =)
Old May 1, 2009 | 10:36 AM
AudiWorld Expert
Okay then...* IT * was removed.
 Pouria Savadkouei
 Michael S. Palmer
Old May 1, 2009 | 12:08 PM
gak27's Avatar
Default No belly pan here either...
...mine must be w/ Kris'
Thanks for the suggestions everyone!
Old May 1, 2009 | 12:15 PM
Head Cat Herder
25 Year Member
LOL!!!!
