Cat converters are causing the engine
Old May 3, 2009 | 12:38 PM
rrokow's Avatar
Default Cat converters are causing the engine
light to go on. My 1999 A6 with 242K miles needs to pass inspection. My Audi dealer told me to check out the after market cat converters. I was told by the after market dealers that the non-oem cats will not get the engine light to go off which means I cant pass inspection. New Audi cats are $800+ each. Anyone have a work around?? Thanks
Old May 3, 2009 | 01:28 PM
4Driver4's Avatar
Tech Guru
Tech Guru
I've been running an aftermarket cat on my 1999 for three years. No issues.
Old May 3, 2009 | 02:14 PM
rrokow's Avatar
What brand of after market did you use? A buddy of mine works at a local Midas and he told me after installing cats on 2 Audi's the engine light still remained on. Also how much did you pay for them ? Thanks for the response..Much appreciated!
Old May 3, 2009 | 02:31 PM
4Driver4's Avatar
Tech Guru
Tech Guru
First, please try to post your response in the correct location within the thread (check out threaded view).
I used Connecticut Cat and bought a bolt in solution. It took about an hour to install. Is your Midas pal sure that the cat was the cause of the CEL?
Old May 3, 2009 | 11:41 PM
JoeCaymanBWI's Avatar
Invest on a VAG -
Clear the codes and then go to the inspection.
It'll pass with flying colors.
Old May 4, 2009 | 03:51 PM
Boston Driver's Avatar
AudiWorld Expert
Actually, I do not think that will work. Readiness code will not be set....
...if it is not set, they cannot pass the car. If you drive the car enough to get the readiness code set, the CEL will likely come back.
Old May 4, 2009 | 04:15 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Correct. There might be a small window of opportunity if the weather is warm, but it is by no means a slam dunk.
Old May 6, 2009 | 05:46 PM
rrokow's Avatar
Default Thanks you for you input..I may have to bite the
bullet and go for the new cats since I dropped so much $$$ into the car so far. I drive 210 miles daily. The rest of the car is fine..I appreciate your responses
 Pouria Savadkouei
 Michael S. Palmer
SKBrown
Mar 6, 2009 01:36 PM
Jim Bush
Audi 100 / A6 (C4 Platform)
Sep 21, 2007 06:26 AM
MLR A4 now CS
Sep 17, 2004 08:38 AM
Audone
Jan 20, 2002 02:24 PM
Sammay
Performance and Tuning
36
Oct 6, 2001 01:00 PM
