I'd like some opinions on my overheating problem
Old May 3, 2009 | 09:39 PM
BklynRX7's Avatar
Default I'd like some opinions on my overheating problem
OK, so heres the story. If I drive the car on the open highway I can go on forever without overheating, only getting one line past the center of the gauge. If I get caught in traffic or drive on small streets (low speed low revs) the gauge goes to the line before hot and the buzzer goes off. I usually turn the heat on full blast and the car cools back down. I already replaced the clutch fan and the problem remains
I checked the car with the vag-com today and it tells me the coolant temp sensor is bad. So now Im wondering if my car is having any problem at all. I already have an appointment(with money down) to have the waterpump/thermostat ect replaced on tuesday.
So is there any chance the problem has been the sensor all along? Is there any way to tell besides changing the sensor? (which I dont have time to do)
I found a post on here where someone mentioned comparing the temp reading for value 04 and 06 and seeing if they match. They dont but value 04 matches the intake temp exactly so I dont think this method was correct.
Any thought would be appreciated.Thanks in advance for the help.
Old May 4, 2009 | 02:59 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Replace the coolant temp sensor first and see what happens.
If you do decide to replace the w-pump and t-stat, do a full timing belt service including all seals.
zeusbap
Apr 22, 2010 12:23 PM
Ertman
Sep 6, 2009 08:15 PM
wheelman21
12
Jan 10, 2008 09:40 AM
bbkid43
May 1, 2007 06:24 PM
tubey
Aug 4, 2000 05:07 AM
