RS6 transmission troubles
If your getting a tech with poor workmanship or lack of experience. There are alot of items that can get screwed up.
Mark from Chicago just had his trans replaced and a line leaked after the repair. Guess what, yes the whole think had to come out again just to replace a feed line.
Its not like doing open heart surgery and test firing the heart before you close up. You have to close up and then test fire the engine. If you have a leak....you have to open her up again. Not fun.
Back to your issue honestly these cars just shift clunky anyway but where i really feel it going is a slight slipping on hard acceleration and a slow shift to 1st (it clunks into 1) when i stop at a light. Sounds like maybe the rebuilt units were not up to the task if failed immediately. Or maybe they did screw up the install. These transmissions are weak and your car is another example of why i constantly bring it up on the forums as it is as bad as the DRC failures. While i drive hard, i don't drive 3 transmissions hard.
Has anyone else had this happen?
