01.5 S4 Avant error codes
VCDS Version: Release 908.1
Address 01: Engine Labels: 078-907-551-AZA.lbl
Control Module Part Number: 8D0 907 551 M
Component and/or Version: 2.7l V6/5VT G 0002
Software Coding: 06711
Work Shop Code: WSC 63351
4 Faults Found:
17862 - Exhaust Gas Temp Sensor 1 (G235): Short to Ground
P1454 - 35-10 - - - Intermittent
16815 - Warm Up Catalyst; Bank 2: Efficiency Below Threshold
P0431 - 35-00 - -
16805 - Warm Up Catalyst; Bank 1: Efficiency Below Threshold
P0421 - 35-10 - - - Intermittent
17866 - Exhaust Gas Temp Sensor 2 (G236): Short to Ground
P1458 - 35-10 - - - Intermittent
Readiness: 0000 0000
Took it to an Audi dealer when I was only getting errors on bank2, and they said to replace the cat and EGT, and the bad cat caused the EGT to go bad. I have a used cat and EGT coming from a 64k mile 01.5 S4, and I'm considering buying bank1's cat and EGT, from the same seller.
Question: Did me going too long(mover a month) on my bad cat and EGT cause bank1's cat and EGT to go bad? I haven't gotten all of the parts yet, so I can't say if replacing the cat and EGT removed the errors or not, but I plan to do them soon.
*Both EGTs were replaced less than a year ago, according to the records that came with the car when I bought it, back in June.
Hopefully I provided enough information, without too much babbling. Feel free to ask questions.
Thanks in advance,
Scott
I considered some high flow DPs, but I didn't really want to spend over $1k, unless that was it for sure. So, that is when I went to the Audi dealer to have them check it out, and they said it was the Cat, and EGT.
As for the EGT going bad because of the cat, I highly doubt it. EGTs are design to measure high temperatures, so if you got so hot you ruined an EGT, I'm suprised you didn't ruin a whole lot of other things. Your cat would have to be plugged so severly, that the car wouldn't run right.
By the way, if your pulling the motor and up there on miles, you might as well change the clutch disc and PP.
BTW, my car had an RS4 clutch installed before I bought the car, so I'm good on that one.
