Toresn Drian Plug-Noobie Quesiton
Old Dec 20, 2009 | 04:32 AM
Kychucky's Avatar
Default Toresn Drian Plug-Noobie Quesiton
2000 S4 with 6 spd.
There is a drain plug on the end cover that houses the torsen differential. Is the torsen lubricated by the transmission oil?
Thanks,
KYC
Old Dec 20, 2009 | 06:07 AM
donromani's Avatar
Originally Posted by Kychucky
2000 S4 with 6 spd.
Thanks,
KYC
If you are talking about the final drive (black casing mounted to the transmission and which has the driveshaft coming out of it) then yes, this is lubricated with gear oil. It has its own drain plug but I think it shares gear oil with the tranny. Not 100% sure about this though, it could be sealed off from the tranny gear oil.
Old Dec 20, 2009 | 09:44 AM
S4andTLS's Avatar
2000 S4 with 6 spd.
Thanks,
KYC
Yes,they share the same oil. There are two drain plugs, one for tranny,one for center diff, one fill plug
Old Dec 20, 2009 | 06:27 PM
Kychucky's Avatar
Default I only pulled one plug
I didnt drain the torsen - - was this bad?
It took the full amount of gear oil...
thanks
KYC
Old Dec 21, 2009 | 04:27 AM
donromani's Avatar
you probably mixed a little old gear oil in with the new but it's not going to destroy the car. How did you check the fill level? It is supposed to be just below the plug on the side of the tranny if you did it right.
Old Dec 21, 2009 | 08:38 AM
Kychucky's Avatar
Default Bicycle Spoke
I have a bicycle spoke bent at 7mm to check the level. Used it on our A6
thanks
KYC
maaliish
12
Jan 6, 2007 11:24 AM
Bruce M
Jun 16, 2006 03:46 AM
mrwho13
Sep 22, 2004 11:38 AM
YllwA4
Dec 3, 2001 11:23 AM
DrBimmerM3
Jul 30, 2001 04:07 PM
