S4 Problems... Help!
P1606 Rough Road Spec. Engine Torque ABS-SG - Electrical Malfunction A
P0455 Evaporative Emission Control System Leak Detected (no purge flow or large leak)
P1176 O2 Correction Behind Catalyst,B1 Limit Attained
P1177 O2 Correction Behind Catalyst,B2 Limit Attained
P1296 Cooling System Malfunction 17704
P0741 Torque Converter Clutch Circ Performance or Stuck Off
Are any of these easy fix like a loose plug or something? Thx
Fix the EVAP leak and your O2 error codes might go away as well. This might be caused by running very rich or lean.
Cooling system? Is your A/C functioning?
The torque converter is a TIP only thing so I can't help you there, but it sounds expensive.
Forgot to add that my Water Temp gauge only goes to mid Temp about 20% of the time, eaither its broken or I think my pump is messed up, could this be causeing P1296?
It amazes me that the cooling error is not more specific, but based on the other symptoms I have to agree with pber: your thermostat is messed up.
The evap system is a doozy. You will need to pressure test the system to pinpoint the bad valve, hose or whatever it is that is causing you evap system to leak.
The tq converter is another very very common fault and unfortunately is not usually a loose wire/bad sensor. You are likely looking at needing a new tq converter.
As for the evap leak, I also agree that fixing that will likely clear up the o2 codes too. I can source all of the above mentioned parts for much less than the dealer. Feel free to PM me.
:: www.ECStuning.com :: Now with EXTENDED Customer Service hours!! | FIND US ON FACEBOOK!!
Phone: 1.800.924.5172 - Sales: 8:30am to MIDNIGHT EST | Customer Service 8:30am - 8pm EST
Questions? PM us for a quick response! | Email: Pete@ecstuning.com
517 Trans Inc.
186 Main St.
Ogdensburg, NJ 07439
973 823 6320Telephone:
E-mail: info@517trans.com
