Boost leak causing coil pack failure?
Old Jan 14, 2010 | 11:53 AM
Stinkpickle's Avatar
Default Boost leak causing coil pack failure?
I started experiencing a misfire during wot a few weeks back. No misfire during idle or casual driving however. Opened the hood and noticed a vacuum hose had come loose. Secured it with a new clamp and drove off thinking the problem was solved but the wot misfire was still there. No cel until a few days later when I got on the throttle a little and it started blinking and stayed on. Scanned and got a cylinder 1 misfire code indicating a bad coil pack as the likely culprit. So my question, would a boost leak cause a coil pack to go bad? How so?
Old Jan 14, 2010 | 02:01 PM
donromani's Avatar
nope
Old Jan 14, 2010 | 02:07 PM
Yeah, I was thinking that it was a coincidence. I posted to make sure. Could a misfire be weather related (temperature wise?) Today was the warmest it's been since I've been having this problem (at least 15 degrees) and earlier when I was driving the misfire was drastically reduced. Tomorrow is supposed to be even warmer so I'll check it out again.
Old Jan 14, 2010 | 04:58 PM
donromani's Avatar
Possibly, but confirming it would not really help with the diagnosis of the problem. The easiest way to rule out the coil pack is to simply move the pack to another cylinder and see if the misfire moves with it or not.
Stonediggity
Jun 25, 2008 05:26 PM
ADHW
Audi Original "S" Cars
25
May 25, 2007 03:43 AM
Etek
Sep 5, 2006 06:45 PM
audiohs
Oct 8, 2004 11:48 AM
Audragon
Nov 29, 2003 11:27 AM
