Can coolant leak cause misfire?!
BTW, what plugs do you Stage 3 guys recommend?
Have you tried moving the coilpack yet? IIRC you did a boost leak test, right?
As for plugs, many people use the side-fire types on stage3. These are specifically designed for high boost applications so stick with the OEM plugs until you go stage3 yourself. Stay away from iridium. Bosch platinums are what you want.
