TBB help
Loosen/remove (2) 10mm bolts holding on the bi-pipes.
Loosen (2) clamps holding bi-pipe to TBB.
Pop the bi-pipes out of the TBB.
Remove the electrical connection to the MAP sensor, the MAP sensor is the sensor located on top of the TBB.
Remove the (2) allen bolts holding the MAP sensor bracket.
Loosen the clamp holding the TBB to the throttle body.
Inspect for damage.
Be careful when reinstalling not to over tighten or damage the TBB. Tears usually occure on the connection to the throttle body.
I have a spare stock TBB that is in good condition if you need a cheap replacement.
