I have the dreaded ABS/Brake light/beep cluster issue
Old Jan 27, 2010 | 04:16 PM
M3 J0N's Avatar
Default I have the dreaded ABS/Brake light/beep cluster issue
I researched on here and foudn the symptoms on my 00 s4 sedan to point to a bad abs module (common on these cars apparently). I purchased a rebuilt module from module masters and had it installed by my local audi tuner. I am still having the issue after install. The Vagcom will not communicate with the brake system in the car. I contacted modulemasters for technical support and they claimed teh light should go off after 30miles of driving. I have almost 100 miles on the car after the install and the light/beep still occurs. Is there some secret procedure I didnt do? Should i disconnect the battery? Why wont vagcom talk to the brake controller? any ideas? Thanks!
Old Jan 28, 2010 | 05:20 AM
donromani's Avatar
It sounds like the unit is not getting power or the harness is not connected right. Check the ABS fuse. I got my unit rebuilt about 2 weeks ago and the problem went away immediately after install.
RichieB5
Jul 21, 2007 07:47 AM
JacobB
Jun 17, 2007 09:08 PM
Jim Cline
Aug 21, 2004 05:56 AM
Beeman'S4
May 3, 2004 12:12 PM
