Clutch Pressure Loss
If you've replaced the slave cylinder and the master cylinder and you are still loosing fluid I'd check the line to the slave cylinder. If its not that, then I'd take a look at all brake lines.
You may need to park it in the garage and put some pressure on the break pedal overnight (maybe wedge a board between the seat and the brake pedal). If its the brake lines, there has to be a drip somewhere. I'd also take a look under the ABS unit.
Its hard to beleive that a leak can't be found - I means its gotta be there or its got smell from burning right? In the meantime, if you're going to drive it, carry a can of break fluid and top it off everytime you go somewhere.
Sorry a little long winded.
