two turbos into one TB?
just a thought
Here is the theory to twin parallel turbos. (IMO)
The intake manifold pressure will be equal for both banks. On average the mass of the air forced into each cylinder will be the same. The amount of fuel sprayed in (assuming matched fuel injectors) is equal for each cylinder. Therefore the amount of both air and fuel in each bank is approximatly equal.
Now we make the assumption that the turbos are well matched. Maybe within 5% of each other (my guess). The amount of exhaust gases between the banks will be equal, as per above, so the turbos should be very close in output to each other. (A side note is that the wastegates are both fed from the same source and must be very closly matched.)
There will be some differance between flow of the turbos, however they both find thier equalibrium points. This might mean that the one turbo will push slightly more air at a given pressure level. Another thing to take into account is the large volume of air that the innercoolers hold. This also acts as a way to equalize the flows accross each bank.
My explanation isn't as good as I would have hoped. But if you conver everything to electronic analogs it makes perfect sense.. lol
Now with FSI you can have the intake maifolds on the exterior of the engine and a single exhaust manifold between the V. This allows for a single turbo much easier.
