revving oddly during shifts - 2001 Audi TT 1.8L Quattro
Old Sep 20, 2010 | 06:53 AM
leighstudio's Avatar
Default revving oddly during shifts - 2001 Audi TT 1.8L Quattro
I recently purchased a 2001 Audi TT 1.8L Quattro. We bought it with some known problems, but those have been fixed.
In the last week, it has started revving when I'm shifting. I let off the gas and put the clutch down, and it revs. I thought, being new to driving manual, that I was doing something wrong, but it finally happened to my fiance when he was driving this morning. He also said it's taking far too long for the rpms to drop between gears.
Any idea what's causing this random revving? Has anyone else experienced this?
[History: bought Aug 28th, had the timing belt and water pump replaced immediately, last week, had the rack and pinion replaced (right side was leaking), the front cross member replaced (left side had damage), the front left steering arm was replaced, replaced all 4 tires, and alignment.]
Old Sep 21, 2010 | 05:00 PM
J. Patterson's Avatar
Default That is not a commonly reported problem 1st I would
clean the throttle body. In 5 or 6 years on this forum and the other one, I don't remember another report. Good luck
Old Sep 22, 2010 | 06:26 AM
Thank you, J.
Old Sep 22, 2010 | 11:49 AM
VARATEK's Avatar
Default Could it be a Toyota not a TT ?
Also check for obstructions on the floor area around the throttle pedal and give the pedal the one finger push (engine off) to see if movement is easy and returns all the way up. These are drive by wire cars and have no throttle cable or linkage.
Old Sep 22, 2010 | 12:00 PM
Ha, Varatek, I'm fairly certain it's not a Toyota. There's definitley nothing in the way of the pedal. I'll try pushing it down to see how it responds. Thanks.
jeffvan1
Jul 14, 2018 05:10 PM
leeeeke
Mar 20, 2018 08:46 AM
robertmontreal
New Member Welcome Area
May 1, 2017 10:16 PM
Danddia
Jan 8, 2017 08:12 AM
Danddia
Dec 28, 2016 03:27 PM
