01 225QC suspension noise?
Old Sep 26, 2010 | 03:01 PM
RemixTT's Avatar
Default 01 225QC suspension noise?
I've been experiencing a weird squeaking noise going over bumps and thought it was my suspension. I ended up getting all new suspension and all new bushings with defcon kit and (koni adjustable shocks and eibach springs) I love the new setup but the noise is still there. Any ideas what it might be?
Old Sep 26, 2010 | 04:03 PM
TTQ2k2's Avatar
By all new, what specifically do you mean...would be helpful to list the parts.
cheers.
Old Sep 28, 2010 | 02:17 PM
notoriousz1g's Avatar
perhaps it's your strut mount?
Old Sep 30, 2010 | 04:12 PM
GHS's Avatar
GHS
Default Common TT problem
I see you replaced a lot of the front suspension stuff so I am not sure this was replaced but almost every TT has problems with bushings in the front control arms (I always called them the anti-sway bar). When under warranty Audi would replace the control arms, related bushings, sub-frame and new sub frame bolts. Since you probably are not under warranty anymore you might get away with buying new bushings for the control arms and re-torquing the bolts. You could also go the after market anti-sway bar route.
Hope your dash was replaced sometime because that always goes, too.
Old Oct 1, 2010 | 01:50 PM
cko1009's Avatar
Default photo
Would you have a photo of your car with eibach spring set up?
I'm interested in changing my suspension with eibach and wonder how it looks. Sorry I couldn't help with solving your problem ^^
Old Oct 12, 2010 | 05:23 PM
Dirkv's Avatar
Check rear anti roll bar or otherwise the door support. Little wedges 2/3 of the way down, seat in a ltittle matching slot in the frame/doorpost. if its dirty or dry these squeek especially when its cold. just clean and lube
thewraith
Feb 29, 2008 08:17 AM
2.7t up north
Suspension Tuning Discussion
May 31, 2005 02:48 PM
2.7t up north
May 28, 2005 08:19 PM
belevine
Aug 18, 2003 10:00 AM
S4Rules
Mar 17, 2001 01:03 PM
