TT boost tapering off...
My problem is the boost hits 20 psi then tapers off to 10 by redline.
Smoked the intake and checked for leaks, made sure my bypass valve was closing.
If I pull the hose off the wastegate solenoid I get 25 psi all the way to redline. Leaky solenoid? Garbage software?
These cars are designed to protect themselves from engine damage. If the engine boosts too much, or the engine does not get enough fuel it will go into a limp mode where boost is limited to protect the engine. It limits boost by controlling a solenoid on the wastegate line (N75), by closing the electronic throttle or by opening the DV valve. If you are experiencing a limp mode the best thing to do is get the car scanned for codes and to see what is wrong. Look at fuel trims for signs of running lean, and to look for MAF problems, or O2 sensor problems. To look for potential boost problems log Block 115 and you can see the specified Vs actual boost. If you exceed the specified then there is a good chance that you will go into this limp mode. Stock specified is a max of 14 psi for a 2002+ car.
The N75 is an electronic solenoid valve that the ECU uses to control boost. It is located in the intake hose near the back right side of the engine. It has 3 connections.
1. Connects to charge pipe = pressure source
2. Connects to wastegate actuator
3. Connects to intake hose – bleed line.
The ecu will pulse this valve at a high frequency to bleed air off from the wastegate line. It does this based on throttle position and engine load. If the valve, or any of the liens connected to it have leaks then there can be severe boost regulation problems. It’s function is similar to the MBC above. To get more boost people often swap in different N75 valves. These different valves simply have a different response characteristic, and will act different when given the same signal by the ecu. They can get more boost, less boost, or even a big boost spike by swapping N75’s.
