Headlight problem
Old Nov 9, 2010 | 04:13 AM
Craig Blalock's Avatar
Default Headlight problem
I recently bought a 2001 coupe and noticed the driver's side headlight was going out frequently. If you turned the lights off then back on it would work for a while and then go back out. I bought some replacement HID bulbs and changed them both and it worked fine for about a week and now it won't come on at all. Any suggestions? Thought maybe the ballast was bad, but not sure. Thanks
Old Nov 10, 2010 | 03:08 PM
A&AEuroTuning's Avatar
Former Vendor
Make sure everything is connected properly, switch the bulbs from left to right... if that doesnt help you probably need new ballasts...
Old Nov 11, 2010 | 08:12 AM
Thanks....I switched them all around and the drivers side doesn't work no matter what. I have read that it could be the ignitor not the ballast? Any suggestions as to which part I should replace first....
Old Nov 11, 2010 | 11:24 AM
Former Vendor
Well usually the igniter is part of the ballast. In which case you need another ballast if that is the problem.
Old Nov 20, 2010 | 09:21 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Not on a TT...>
The igniter is inside the headlight assembly and likely the problem.
lilwinch78
Audi A3 / S3 / RS 3
Aug 11, 2017 05:15 AM
John Elway
May 5, 2017 08:16 AM
allisterbmc
Jan 8, 2007 06:08 AM
lfloodt
Apr 23, 2003 11:46 AM
audi devil
Feb 4, 2002 08:34 AM
