CV JOINT / AXLE REPLACEMENT
Old Nov 22, 2010 | 10:47 AM
skylordd's Avatar
Default CV JOINT / AXLE REPLACEMENT
How difficult is it to replace the axles/CV joints as a unit ? Can this be done at home?
Old Nov 22, 2010 | 04:58 PM
AudiMick's Avatar
I would do it in the garage. It will make a terrible mess on the carpet in the home.
Easy job, you probably need a triple square bit and a big (either a 14 or 17 ??mm hex + a breaker bar to loosen the hub.
You can just replace the boot and re-grease if it's just torn and the axle isn't clicking. Messy but cheap, under $20.
Old Nov 23, 2010 | 02:18 AM
skylordd's Avatar
Default CV /AXLE Replacement
Thanks, I think this will require a whole axle replacement, dont have clicking but I do have vibration when I accelerate and go up grades. Dont know which one is the problem so I guess i'll replace both. Tires are brand new so I know its not them, one other check will be the motor mounts. if it isn t them then its the axles . At least thats what I was told.
Old Nov 23, 2010 | 02:25 AM
skylordd's Avatar
Here is the tools needed to do the VW removal / install so I assume the Audi is the same or close. Complete description of the task is on the RAXLES Website .
Volkswagen MK4 axle installation:
Tools needed:
Good Impact Gun! This is necessary for removing and installing the 30 mm axle nut. Cheap impact guns will not have enough to remove the factory nuts nor will they have enough to replace the new axle nuts!
A REALLY good friend who has some clue to what you are attempting!
30 mm 12 point socket for removing axle nut
10 mm 12 point (Triple Square) male bit for removing OEM axles(See last Picture on page)
8 mm 6 point Allen bit for installing New axles
Several different length extensions for the sockets
13 mm socket or wrench for control arm
16 mm socket or wrench for sway bar
19 mm socket or wrench for removing tie bar ends
Hammer and Pointed Chisel or to make it Very easy an air Impact Hammer with a pointed tip.
Old Nov 23, 2010 | 05:49 AM
AudiMick's Avatar
Tools needed:
That sounds about right, I have seen some TTs with an allen bolt for the axle.
lsimburger
Aug 12, 2015 12:33 PM
ChuckDee
Jan 25, 2005 01:44 PM
wws03
Aug 22, 2003 06:20 PM
K-solo
Feb 23, 2003 06:37 AM
K-solo
Feb 17, 2003 07:48 PM
