Power Steering replacement
Old Nov 29, 2010 | 09:02 AM
whemurad's Avatar
Default Power Steering replacement
Lately I started noticing a weird sound when starting to turn right on my 2001 Audi TT Quattro Roadster specially in low speeds or even when it is stopped. It is fine when I turn left, but when I turn right (in the beginning) I hear a sound of "metal hitting metal" as if the cv joints were going bad (tak tak tak sound). Maybe they are!
Anyway, a mechanic friend of mine asked me to check the power steering fluid first, since the noise is not too loud. I checked it and the oil is smelling like burned. Then he told me to drain the current oil and replace it. I already found out that the correct replacement oil is any G 002 000 compatible, i.e. Pentosin CHF 11S (approx. $20/1liter).
Now, in the repair manual, it doesn't mention anywhere that the power steering fluid should be replaced, only checked. Not even in the scheduled maintenance chart. Furthermore, the level checking is kinda awkward. So the questions I have are:
1. The repair manual says that the correct level must be anywhere between 2mm above the MIN and 2mm below the MIN. Yes, both 2mm around the MIN, not MAX. Is that correct? Or the Bentley's repair manual has a typo? ( I have the 2000-2006 Audi TT Service Manual section 03-31). Is it really MIN +- 2mm range? Or no, it should be MAX+2mm and MIN-2mm range?
2. Mine is about 2mm above the MAX. Could that be the reason of this clicking noise when turning right?
2. Should I replace the power steering fluid since it is smelling like burned oil, even though the repair manual does not suggest/recommend it?
THANK YOU in advance for you help. Much appreciated!
Old Nov 29, 2010 | 09:26 AM
whemurad's Avatar
The correct title for this thread would be: Power steering fluid replacement. Sorry.
MISSY2684
Performance and Tuning
Feb 19, 2009 09:46 AM
leonpro
Mar 21, 2007 08:39 AM
AW #29529
Jan 31, 2005 05:07 PM
bigalk (back in UK)
Sep 15, 2003 07:48 AM
PR_A4
Nov 8, 2002 06:18 PM
