propane/93 hybrid TT 1.8t.
also, im getting almost 65mpg highway and 40 mpg city. lamda is spot on, and adaption is more then fine. egt temps are also on par. even at 23psi. engine is runing better then ever.
if intersted, post up.
so how much, well very little if doing a gasoline lpg hybrid. here is a example. i used a small lpg torch at idle, and the lamda jumped from +5% to -%25 then corrected back to +3%.
my next two mods are going to be using a old n249 wired up to the fog lights for lpg on/off.
to easy., and try it at your own risk.
