tt coolant leak / water pump ?
It seems to collect on the lower lip of the ribbed belt shield and then blow back on the the pan. I would think it might be from the water pump but the t belt cover is very secure and I replaced the water pump along with a complete kit with the t-belt about 5000 miles ago.
Has any one had a water pump develope a leak and show coolant leakage this way. I have the car up on stands, have pulled all plastic panels and just can not find a source convinceing enough to dive in and go at the water pump.
discussion please. Thanks
When loking under neith the car there was plenty of evidence of a coolant leak but no apparent source.
I spent and hour under the car with it running and no leak. Next day it was driven to work and ever hight it was low again.
SOOOOOOOOO got a pressure tester and hooked up the pump. 10lbs of pressure and the t-stat o ring gave way to a healthy flow.
This t-stat, oring and elbow are only 6 months, 5000miles old. I replaced the genuine Audi oring with a locall after market oring and reinstalled te t-stata and elbow and it passed the pressure test. Now we will be diligent in watching the coolant level for a while. QUESTION. I do not like the way the plastic elbow seems to bow out betweeen the two bolts that hold it. Is this normal. I would think that a sealing elbow like this should be srong enough to compress the oring and no bow. ??????
Any one with experience on this. Would sleep better if this is normal
thanks.
I also noticed that the Serpintene belt that is only 6months 5000 miles old is very cracked up. It was part of a complete T-belt kit I installed.
I am replaceing it but it sure is not due I would think ?????
thanks for the help with this Audi TT I love this car and my sister couldnt afford the upkeep if I didnt do the work for her,
But I still want one
But O got it from one of our major suppliers . If it fails again I will look into the maufacture location and let you all know. Thanks The leak seems to be fixed will be diligent at inpsecting the t-stat for leaks for a while.
