engine coil
Old Dec 15, 2010 | 06:58 AM
john123456's Avatar
Default engine coil
hi can any1 help . tt 180 quattro when i push the gas the engine is stutering and then like a power booster it shoots away . mostly happens when you are needing instant speed , has just newly started happening after i got a service ,the garage said its not much to worry about but take it easy and dont floor it when driving!!! also said sumit about it needing an engine coil replacement . any help of info would be great cheers
Old Dec 15, 2010 | 03:24 PM
netabuse's Avatar
If the shop says you need new ignition coils, it probably needs new ignition coils. You'd have a rough idle and power loss.
Could be other things, but ignition coils are pretty simple to diagnose and obvious to fix if they're broken.
Old Dec 15, 2010 | 05:45 PM
AudiMick's Avatar
Sounds like a great repair shop! Let us all know so we can avoid them.
If the coils are a problem you would probably would have a CEL.
RET
9
Mar 24, 2017 08:35 AM
AudiTTude
Dec 24, 2006 07:49 PM
djtalon
May 27, 2003 06:36 PM
Subotai
Mar 10, 2003 11:22 AM
