Bump Stop & Bilstein Sports
My question is if the stock bumpstop is going to fit on the Bilstein under their blue cover. It looks like the shaft of the bilstein is way bigger than my stock struts.
I have not tried anything yet, but I figured I would ask before I get to it.
Thanks
Thanks
cheers.
What about the rear shocks? I don't remember seeing any bump stops in the rear. Are the in the rear shocks? Do the bilstein shocks have bump stops?
In back assuming quattro, again it's not external on the damper. It's inside the spring... the rubber piece built into the lower spring perch
With Bilsteins, just bolt 'em in
