GIAC vs. APR ECU Upgrades
Old Jan 3, 2011 | 12:23 PM
BlueTT225's Avatar
Default GIAC vs. APR ECU Upgrades
Can't decide between the two. According to each website it seems that APR produces more power and torque based on dyno charts that are available on both sites( APR's looks a bit fabricated if you ask me) can anyone confirm this? Furthermore, I have heard that APR ecu upgrades have A few bugs. I look forward to hearing other opinions and thoughts.
Regards,
BlueTT225
Old Jan 10, 2011 | 12:31 PM
Slush Puppie's Avatar
most chips are essentially the same, your best bet is to probably go with whoever has a local installer.
Old Jan 12, 2011 | 06:04 PM
J. Patterson's Avatar
Default I think you got that backwards
My APR 93 program has been great for 7 years now but it IS true that--
A few BUGs have APR ecu upgrades. :-)
Old Jan 17, 2011 | 04:51 PM
enordrum's Avatar
Not on your list but go with Unitronics.
Old Jan 17, 2011 | 05:24 PM
BlueTT225's Avatar
Why? what advantages does unitronic offer when compared with giac?
Old Jan 24, 2011 | 03:18 AM
enordrum's Avatar
I'm getting better gas mileage, gained 2mpg city. Performance wise, car runs much smoother, pulls hard to redline. Any chip from a major chip tuner will be decent on a stock turbo, eventually you may want to go big turbo though as most do sometime after chipping. Unitronics has the most and the best bt files. Only thing you will not get with uni is ability to switch octane programs which I could care less for.
Uni stage I=260hp (91 oct) stock
stage I+=273hp (93 oct) stock
stage 2=285hp (need a down pipe)
I've heard apr, revo and Giac may throw some codes, I haven't seen any from my uni tune. There are a couple flashed ecu's fs on vortex right now, you may want to check them out. There is a revo, uni and a Giac right now but make sure the ecu matches if you end up buying one of those.
Old Jan 26, 2011 | 04:04 PM
GeTT da NeTT's Avatar
Default Chips
I too have run APR for some time without issue (6 years). I actually looked into Unitronic and passed because thay had to hardwire my ecu. That has probably changed. The other comments on Unitronic are true.
I have had good customer support from APR and can recomend them.
The best recommendation is to buy local if you can.
Good luck!
PainDOC
17
Nov 1, 2018 06:00 PM
3rdGearEvo
S4 (B8 Platform) Discussion
14
Oct 1, 2015 07:15 AM
ScottCNelson
Sep 27, 2015 02:41 PM
virtualsteroids
A4 (B8 Platform) Discussion
Sep 26, 2015 08:45 PM
PainDOC
Sep 26, 2015 07:32 AM
