Free Expert Installation on all KW Suspension Purchases!!!
Old Feb 4, 2011 | 11:47 AM
info@ecodetuning's Avatar
Former Vendor
Default Free Expert Installation on all KW Suspension Purchases!!!
For a limited time, EuroCode Tuning is offering complimentary (free) expert installation on all KW suspension systems purchased from us.
This offer is open and valid to all customers who purchase a KW suspension system from Eurocode Tuning. Most systems are in stock at our California warehouse, however from time to time they are shipped via air freight from Germany.
Please give us a call at 310-294-8108 if you would like more information on your specific application, or you may email us at info@ecodetuning.com
KW Suspension Inox Line features:
~Highly corrosion-resistant
~Unsurpassed quality
~No signs of wear at the adjustment mechanism – also during long use
~Trapezoid thread in stainless steel eases height-adjustment
~Perfect look – permanently
~High load tolerance
KW Variant 1
Sporty Handling with factory pre-set damping
The ideal systems for customers wishing to rely on the experience of our engineers to set the damper setting, yet determine their own degree of lowering. In extensive driving tests our engineers have set the dampers for the best balance between sporty driving, comfort and safety. The user is then free to decide the best height setting for their use and preference.
~Optimally pre-set
~Sporty harmonious damping technology
~Stainless steel technology "inox-line"*
~Individually height-adjustable
~Lowering range approved by the German Technical Control Board (TÜV)
~Fully finished complete solutions
~High-quality component parts for long durability
~Comprehensive documentation for easy use
KW Variant 2
Sport Handling with adjustable rebound damping
The system intended for the experienced driver who does not only wish to determine the individual lowering of his vehicle, but also wishes to carry out setup adjustments. The adjustable rebound damper allows adjusting the pitch and roll behaviour of the vehicle and therefore the driving pleasure can be adapted to the own requirements.
~Damping technology with individually adjustable rebound
~inox-line* stainless steel technology
~Individually height adjustable
~Adjustment parameters approved by the German Technical Control Board (TÜV)
~High-quality components for long durability
KW Variant 3
State-of-the-art technology from motor sports for more performance on the road.
The separate and independently adjustable rebound- and compression damping allows for an individual suspension setup for different uses and preferences. The unique patented system with its two-stage valves allows a rebound damping adjustment (comfort) and a compression adjustment (driving dynamics) in the low-speed range while the high-speed range which controls the driving safety, is fixed.
~Damping technology with individually adjustable rebound- and compression technology
~Infinitely variable rebound damping adjustment
~14-way adjustable compression damping
~Unique, individually working damping force adjustment
*some restrictions may apply, please contact us for details
info@ecodetuning
A4 (B8 Platform) Discussion
Feb 8, 2010 12:08 PM
info@ecodetuning
A4 (B7 Platform) Discussion
info@ecodetuning
info@ecodetuning
info@ecodetuning
