timing belt install question
Old Feb 25, 2011 | 07:38 AM
Dillon1.8t's Avatar
Default timing belt install question
I was wonding if anywone cold help me. I installed my timing belt kit this weekend I ordered from dieselgeek.com and got the entire kit. I put all the new parts on water pump dampener tensioner pully. I got the belt on and then removed the dampener pin and when i was looking at my belt i just doesnt seem tight enough.. I was just looking for some imput becuase i wasnt entirely sure how the timing belt tensioner worked..
Thanks everyone!
-Dillon
Old Feb 25, 2011 | 12:24 PM
typ44q's Avatar
Did the old tensioner feel like it had more force on it?
After you have everything in place turn the engine over a few times by hand this should even out the tension on the belt between all the different pulleys and give you a chance to see if everything is correct before trying to start it.
Old Feb 25, 2011 | 01:14 PM
Dillon1.8t's Avatar
yeah i rotated everything and it all looks good but when i pull on the belt it just seems like the belt has to much play in it. is there a way I can test the tension?
Old Feb 28, 2011 | 04:24 AM
typ44q's Avatar
There are gauges that you press against the belt to measure the deflection per X amount of force but you would have to have the gauge and know what the value is. The old school way of doing it before VW/Audi started with the automatic tensioners was that you wanted enough tension on the belt to be able to twist it 90 degrees (in between the pulleys that are spaced the furthest apart) without using too much force. I know that is kind of vague but that is how I have always done it on non auto tensioner cars and have never had a problem.
Did you check that the tensioner was able to pivot freely after it was bolted on and before the belt was in place?
I had a problem with a tensioner from diesel geek where the pressed in metal sleeve on the pulley was the wrong size (off by about 1mm) but it was enough to keep it from pivoting so when it was torqued down it would not pivot. I swapped the sleeve from the old tensioner to the new one and it worked fine. If that is the problem and the pin has already been pulled you might have to get a new tensioner (I have never been able to get the pin back in to one)
SkiBum2
Feb 14, 2012 05:03 AM
mattfl
17
Aug 13, 2007 03:19 PM
TTracey
Jul 17, 2004 05:48 PM
Burnz
Jul 25, 2003 07:07 AM
Clues
May 22, 2002 10:26 AM
