TT on FK Streetline Coilovers
BEFORE FK:
@78xxx, yesterday id lower my TT with fk streetline coilovers, overall i got a good drop in the front with about 20 threats left, the back i am not so sure about.
Front:
the front was a pain we had to do a lil modifying to the spring compressor cause it was hit the inside top
the front passenger side was even worst, we had to hit it with two spring compressor,and still not enough, end up having to unbolt the bolt joint to get enough
room.
after couple hours of work it got done, fyi i am regular person with basic car knowledge.
after:
Rear: before
the rear was a lot easier and faster. jack up the rear took off the wheels, the inner panel out:
took the shock absorber out and the bottom bolt and had my dad step on the caliper, and just pull the spring out with my hands,
bottom sway bar link and shock
Old spring is out
New:
After:
the rear is all the way down as far as it goes,and i am not happy with it, did i do anything wrong, which i am sure i did, i am open to any suggestion and comments
In this pic the adjusters (red arrow) are in the max lift position. I'm sure you screwed them all the way up against the perch for max drop? If you're already there, you can remove one or both of the adjusting rings and run the spring against the perch *with no adjusting rings*
all of the above should get you a 1/2 inch plus
Where did you get your suspension setup? Good Price?
I am looking for spacer, preferably 15mm so if anyone out there has theirs FS let me know
here a links off other tt owner running fk coils http://forums.vwvortex.com/showthread.php?5243677-TT-on-FK-Streetline-Coilovers
