Low Temperature Issue
With the AC off only one electric fan should run at normal temps. There is a thermo-switch in the radiator to regulate the fan. There is a also a fan control module that controls all of them.
Both of these items fail a lot.
From your results it sounds like the gauges are good.
It's probably either the thermostat or the fan thermo switch/ controller.
Your car has low miles but is 10 years old.
Get an OEM thermostat and install it. It's a bit awkward but 45 minutes with the right tools.
The OEM Audi/VW thermostats tend to fail open, aftermarket fail closed (with sometimes catastrophic results).
If that doesn't help investigate the fan situation.
FYI the plastic fitting over the thermostat become brittle over time, they can break or leak . Cheap part but very annoying. Make sure you use Audi/VW coolant as typically the parts store stuff doesn't mix well.
I don't know if you have done the water pump/ tensioner/ timing belt service. Your car has low miles but 5 years is the recommended replacement.
I have not done the pump/tensioner/timing belt service. I wonder if the 5 year replacement recommendation you mentioned is based on expected typical mileage in that time frame, or on parts wearout strictly due to age and/or mileage. I will have to explore this further. Not something to look forward to.
Depending on where you live and the local climate and whether the car is garaged can make a difference.
In 2001 Audi was using plastic water pump impellers and those original ones are known to break up. The tensioner was a high failure point.
I have owned Audis for over 15 years so having seen this happen I tend to err on the safe side.
With that car I would be looking at changing it within 1 year. If you can DIY it's not really that bad . I have done other FWD transverse cars and it's about as easy as a Honda or Toyota.
