Transmission oil change procedure
Old Jul 27, 2011 | 12:17 AM
A8nightmare's Avatar
Default Transmission oil change procedure
I know this has been discussed, but my question is ..Has anyone changed their own transmission oil and filter on the D3? If so do you have the procedure?? I am going to do it soon one way or another and I will post the good the bad and maybe the ugly
Old Jul 27, 2011 | 12:06 PM
Vicl's Avatar
Are you sure you have to do that?
I’m not sure you need that. Unless you have really high mileage I would not even bother doing that. The filter itself does not make sense to change at all. In modern cars it is ALWAYS clean. Transmission fluid is very expensive and then you’ll have to do transmission adaptation. But even then you will not be able to change 100% oil 
Personally I’ve changed transmission oil many times on my old Audi V8, 1991, but I’m not planning to change it at all in my Audi A8, 2007
Old Jul 28, 2011 | 06:52 PM
MP4.2+6.0's Avatar
Tech Guru
Default In Bentley? ... Where is filter?
Haven't opened Bentley in a while (marooned on an old PC), but should be in there.
Have you checked on filter specifically. From what I have understood, it may be integrated right into the lower pan...meaning you have to replace that whole unit. Maybe just call/stop by an Audi parts counter to find the answer to that. If it goes that direction, you could check with a ZF distributor too (and same for fluid), since underneath it's the AWD version of the standard ZF 6HP30. Another post referenced ZF prices are apparently more reasonable than Audi's, and obviously they know their own trannies as far as routine service parts.
newguy662
16
Oct 7, 2005 08:03 PM
AJN334
Apr 11, 2005 04:45 AM
s4florida
May 31, 2004 03:59 PM
A4FR
Feb 25, 2003 07:57 AM
dbtong
Feb 4, 2001 11:47 AM
