Air Con & Wheel Caps query ??
Old Jul 27, 2011 | 11:29 AM
Gaity's Avatar
Default Air Con & Wheel Caps query ??
Hello all,
Firstly I have a 2003 A8 4.2 Sport with 19" 12 spoke alloys.
I've read lots of different threads about this and especially for the air con issue, but I thought I'd post a thread anyway.
Air Con
When I put the air con on a low setting in the summer I get lovely cool air coming from the centre vent closest to me but all other vents blow out slightly cool or luke warm air!
Basically if it's hot outside then despite trying all air con settings only 1 vent blows cold air.
Could this need a gas recharge or is it likely to be a faulty valve?
Alloy Wheel Centre Cap
Mine keep falling off!! They do look like they might be copies and no matter how tight I think they are on, within a few weeks off 1 will go! I've lined up the valve cap correctly but when doing this the centre cap won't go on properly?
Do the original Audi caps have a hole in the front which you need the small metal tool to remove them cos mine don't have this so they could be fake?
Cheers all.
Old Jul 27, 2011 | 11:42 AM
jakematic's Avatar
Welcome aboard!
Originally Posted by Gaity
Air Con
First check the centre vent temp which can be adjusted with the setup button on the air con controls.
If it's not in the middle it will blow cooler air.
That's the extent of my air con knowledge, but there are a lot of folks here who know it better.
Yes - that's what the pin in the tool kit is for.
Old Jul 27, 2011 | 11:45 AM
Gaity's Avatar
I've tried playing with the centre vent temp but to no avail !
Old Jul 27, 2011 | 05:36 PM
FlyTyinFool's Avatar
If there is air conditioned flow coming from any vent, then it isn't a question of needing a charge. It's either cold or it isn't. This sounds more like a mode door issue. Like jakematic, I'm no AC expert. An advanced search will uncover a number of posts regarding this exact issue though.
Old Jul 28, 2011 | 06:31 PM
MP4.2+6.0's Avatar
Tech Guru
Default See my other post just now by chance
to another malfunctioning A/C thread. Lots other ideas/pointers in that thread too.
https://www.audiworld.com/forums/sho...php?p=24173427
A4AdMan
18
Jul 19, 2022 09:11 AM
Marc Kaplan
S6 / RS6 (C7 Platform) Discussion
Dec 1, 2017 08:04 AM
AaronL
Mar 10, 2009 07:05 PM
Porsche+Audi
14
Aug 4, 2008 03:43 AM
XcellR8edAudi
Aug 20, 2003 05:05 PM
