maybe this will solve your trunk closing issue
I adjusted the bar in the trunk sill that the latch strikes and holds to a more elevated position. That adjustment allowed the lid to stay closed when the motor closed it. However, the striker being higher meant that the lid no longer fit flush with the body.
So, after looking to see how the lid is adjusted as to position it seemed to me that the key lay in the three bolts that hold the passenger side hinge to the quarter pannel. I loosened the bolts and adjusted the deck lid so that it fits flush with the quarter pannel even with the slightly raised striker position that allows the lid to close via the auto close button. Also ther is an adjustable pad at the back of the hinge...I dont know exactly how it comes into play, but I dialed it all the way down incase it would keep the hinge from getting to its lowest possible position.
The soft close function still does not engage to pull the lid snug...the lid simply closes in one motion, the same as it does by hand. I'm just happy to have the auto-close feature available once again, and I see no need to get the soft-close functioning. I hope this might be an answer for others of you who have the same symptoms i had.
- starts to close and gets very near closed
- engages as though it was by hand, but not hard
- get's sucked down a little more by the motor
My guess is it disengages the motor at the last second to let the lid "slam" shut, then snugs it up.
The softclose motor operates on mine even when closed manually.
