code 16840 and code 01217 anyone know where to start?
Old Aug 4, 2011 | 07:38 PM
JP19640_0's Avatar
Default code 16840 and code 01217 anyone know where to start?
my car just through a MIL light so I scaned it with my vag and got this
1 Fault Found:
16840 - EVAP System: Very Small Leak Detected
P0456 - 002 - Lower Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 0
Fault Frequency: 1
Mileage: 113779 km
Time Indication: 0
Freeze Frame:
RPM: 1622 /min
Load: 47.4 %
Speed: 52.0 km/h
Temperature: 92.0°C
Temperature: 28.0°C
Absolute Pres.: 0.0 mbar
Voltage: 14.097 V
and.
1 Fault Found:
01217 - Side Airbag Igniter; Driver Side (N199)
001 - Upper Limit Exceeded - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 1
Fault Frequency: 45
Mileage: 108256 km
Time Indication: 0
Date: 2011.06.02
Time: 21:58:51
anyone have an idea where to start looking?
Old Aug 5, 2011 | 03:30 PM
JP19640_0's Avatar
no one?
Old Aug 5, 2011 | 07:31 PM
FlyTyinFool's Avatar
Simple fix is tightening the fuel cap. If that doesn't do it, the only test I know of for the Evaporative Emissions System is a smoke test. I have no idea how a DIYer like myself would even do that.
Old Aug 5, 2011 | 08:08 PM
Brozee's Avatar
Patience... Geez
Clear the codes and re-scan see if they come back. My car wasn't scanned for a long time and pulled up a lot of faults then they were cleared and near to none came back.
Old Aug 5, 2011 | 09:16 PM
JP19640_0's Avatar
ok thx guys, I did check the gas cap and its on tight. I will clear the codes and see what happens
Old Aug 5, 2011 | 11:17 PM
pcamaj's Avatar
Evaporation can be ur purge valve... It happened on mine. even though I got a c6 I have the 4.2...
Old Aug 7, 2011 | 10:03 AM
JP19640_0's Avatar
So would that mean I have to purge it? Sorry not to sure what that is.
Also can anyone tell me what's going on with the airbag light?
Would it likely be a sensor or something?
Old Aug 7, 2011 | 11:23 AM
tashakes's Avatar
Could be something as simple as a bad connector or as bad as a bad airbag, but airbags rarely go bad. Most times the problem is the connectors or harnesses. Clear the code and see if it comes back on.
 Pouria Savadkouei
 Michael S. Palmer
Old Aug 7, 2011 | 01:29 PM
pcamaj's Avatar
U have to locate the purge valve where it is, then look for loose connections, if that doesn't solve it, try replacing the valve. It's cheap... Worth trying. Anyone here with the bently manual can tell u where the valve is located.
As far as the airbag light, my buddy has the same issue, in his d3 , its most likely a bad sensor, or connection.
We reset it once with vag- com cable. It worked for a while then it came back and resetting didn't do it.
Old Aug 7, 2011 | 01:38 PM
JP19640_0's Avatar
great thanks for the tips guys, I'll try to look for the purge valve and reset the codes
