Need help with rear brake calipers.
Old Aug 20, 2011 | 11:55 AM
Futuref1's Avatar
Default Need help with rear brake calipers.
I replaced the pads on the rear brakes of my 90 Quattro, but now we can't get the caliper's pistons to retract. Any help would be greatly appreciated. Thank you.
Old Aug 20, 2011 | 01:14 PM
Luxus Panzer's Avatar
take the pads back off. then you have to turn the piston as you push. C-clamp and a "brake cube" work well.
Old Aug 20, 2011 | 01:28 PM
maineman's Avatar
Default This is the correct tool..............
http://www.amazon.com/Professional-D.../dp/B000IB40L6
You have to apply pressure as you rotate them back in.
Sometimes you can rent them from your parts store or they may let you borrow them.
good luck
Old Aug 22, 2011 | 08:11 PM
Blago's Avatar
You don't need a C-clamp. Just take a pair of needle nose pliers, stick them into the two slots of the piston, and turn clockwise as you push inward, the piston will retract.
Futuref1
Aug 20, 2011 01:30 PM
parkale1
9
Jan 15, 2010 05:45 AM
owdeeS4
Jul 14, 2002 03:23 PM
green_bud
Sep 13, 2001 07:01 AM
A4Nut
Jun 2, 2001 12:39 PM
