Adjusting windows and seals on Cabriolet
Old Aug 29, 2011 | 11:34 AM
JMS-DK's Avatar
Default Adjusting windows and seals on Cabriolet
Hi Guys.
I'm new to this forum however I have read a lot of threads and this place seems to be the one to get help from other Audi owners.
I have just recently bought my dream car, an Audi cabriolet from 96.
The body is good, the top works though I think it needs to be replaced in a couple of years.
I do though have a few issues with the side windows both door and behind the door, that needs to be fixed.
Passengers side is ok the seal and the windows are properly aligned.
the drivers side is another story. It seems that the rear window has been replaced.
I detected that the rear side window does not completely slide in
completely into window seal on the convertible top
Side window must slide completely into window seal on convertible top.
Also the door window in the drivers side does not completely press into the rear window seal, which makes some noise when driving.
My question is how can I adjust it, so both the rear side window slides correctly into the window seal and the door window makes contact over the entire lenght of the rear window seal?
Is it a easy thing to do or does it need a pro?
Thanks a lot for any answers.
J.
rear side window
Old Aug 29, 2011 | 12:21 PM
Loudgoldwing's Avatar
Please take/post pictures to show how big of a gap we're looking at, here. Holding a child's ruler in MM next to any gaps will help.
To claify, I'm trying to see if we can adjust your window seals on the roof and rear window, or if we're going to need to pull the rear panel to adjust the position of the rear window itself.
I'm thinking that the rear window isn't going all the way up, which is leaving it at an angle. THAT definitely will cause a gap between the 2 windows, as well as the top's seal against the rear.
Or, it could just be that the rubber trim needs adjusting. It happens. It's rare, but it happens. Either way, I think I can help with posting some instructions for you. I just need to be able to see which set I should post. It takes me FOREVER, so I'd prefer only do it once.
Cheers,
LG
Old Sep 5, 2011 | 11:28 AM
JMS-DK's Avatar
Cheers,
LG
I have tried adjusting the rubber trim, by bending the alu holding the rubber seal inwards. It didn't solve it.
I have measured both passenger side and drivers side. Passenger side is approx. 148,5cm and drivers side approx 148cm, so it needs 5mm in total length.
The distance on the B pillar is 7mm between side window and rear side window, that way I think I also need to adjust the door window as well, to maintain the proper distance of 7mm.
Old Sep 5, 2011 | 11:33 AM
JMS-DK's Avatar
Default side window adjustement Audi Cabriolet
Cheers,
LG
It would be wonderfull if I could see instructions, also to adjust the roof and the sealings properly.
It's my first cabriolet, and I have intended to keep the car for a very long time.
Have you done it all by yourself when it comes to adjustement or did you get help in the beginning, It might be easy shen done a couple of times....
Thanks for your reply, also
Old Sep 5, 2011 | 02:02 PM
hubturn's Avatar
With the windows all the way up, take a side picture from farther away showing the door and rear window with the top up and with the top down. Then with the top down, take a picture from the rear showing the alignment of the two windows. This will tell us if the windows are not all the way up, and if the windows might need an adjustment torward the interior. Is english your second language, since you are in Denmark?
CMillA5
Audi A5 / S5 / RS5 (B9)
18
May 7, 2019 09:16 AM
man_utd_4eva_727@hotmail.co.uk
Oct 22, 2016 06:22 PM
knepster1
Oct 29, 2008 10:10 PM
Chopper333
May 23, 2008 09:43 AM
Bob Hill
Jan 27, 1999 10:51 PM
