Audi a8 3G mmi retrofit
http://audiforum.us/threads/mmi-3g-n...retrofit.9650/
and
http://a6retrofit.tripod.com/article...gretrofit.html
It will probably get you an idea of what is needed. With the limited knowledge I have, a new center console control, main brain unit and nav drive will be needed. The MMI also controls HVAC, seats, AMI/iPod/CD Changer, rear view camera, ambient lights, TPMS, and on and on and on, so I am not sure the current modules will connect to the newer 3G.
You have your work cut out for you, but it will be interesting to see your results if you decide to plunge into it.
Cheers
Edward
http://audiforum.us/threads/2g-to-3g...roubles.10419/
http://audiforum.us/threads/s8-d3-mm...version.10015/
Also, there are several cases on tyresmoke.net. I don't have them bookmarked so you will need to search:
http://www.tyresmoke.net/forum/audi-a8-s8/
"craigyb" on tyresmoke.net has successfully completed several D3 MMI 2G to 3G conversions though I believe all were on UK models (which may or may not make a difference). He seems to have a buiness in the UK specializing in system retrofits for various Audi models.
Coming from the MB crowd where STAR systems cost an arm an a leg, and even a hacked one costs upwards of $1500, this is a bargain and works well for most of us.
