1995 90 stereo wiring diagram
Old Sep 5, 2011 | 11:22 AM
coriard's Avatar
Default 1995 90 stereo wiring diagram
Hello all,
So I pulled the stereo out so I could have it seated into it's slot a little better, and have it flush. However, like 3 or 4 of the wire ties popped off and now I'm not sure which to tie back together. I used a wiring harness to attach to the stock harness so the stock wires did not need to be cut and tied themselves.
But my problem now is no dash lights of any kind. The fuse is good, but it will once in a while dimly light up for a moment when I hit a pothole or something. So the wires inside are obviously just barely touching at some point, but I'm not sure which ones are the correct ones and I would prefer not to play guess and check for 2 hours.
Any help?
Thanks all!
Old Oct 2, 2011 | 08:44 PM
my1990audi90's Avatar
I have the same problem....any luck so far?
Old Oct 3, 2011 | 10:30 PM
Black Vengeance's Avatar
There is a stock radio wire that is used for lighting the stock stereo. Go through the wiring and make sure all bare wires are taped off and not grounding out on anything. Had a simmilar problem where the rear speakers would only work when the lights were on. turns out the light wire was in contact with the amp power feed wire.
Old Oct 4, 2011 | 09:09 AM
CRAZY_RUSSIAN's Avatar
maybe this will help http://12v.org/mods/index.php?include=stereo
a4b7
Mar 25, 2007 08:24 AM
AznA408(NikkaPuhlez)
Mar 28, 2004 12:58 PM
4showa
Jun 14, 2003 05:13 PM
Flyer
Dec 11, 2002 06:44 PM
selfproclaimedv8buff
May 13, 2002 08:11 PM
